devildg4671
Thread starter- Joined
- Feb 19, 2011
- 38
Hello,
I purchased a Michigan Wheel Apollo Stainless Steel 3 blade prop recently for a my 1999 Evinrude 50hp 4-stroke,
It came with the prop, thrust washer and hub. The problem I'm encountering, after installing it and gently tightening down the prop nut to put the cotter pin in the prop doesn't spin freely. It appears it's pressed against the lower unit.
I doubled checked the prop and it's the correct one.
