prop diameter
scr350
i was wondering if someone could tell me the diameter of this prop quicksilver 48 8278 A41 17P i know its a 17 pitch but cant find any info one it ! thanks in advance
steelespike
Re: prop diameter
I couldn't find anything as well.
If you measure from the center of the bore to the tip of a blade and double it you'll have the diameter.
Diameter is a secondary consideration. If the prop is intended for your application the diameter should be right.
If you're changing pitch the diameter may be different. Usually as pitch goes down diameter goes up and visa versa .
