BigBoatinOkie
Thread starter- Joined
- May 28, 2009
- 763
Howdy. I have an '84 wellcraft 18ft. bowrider with a Merc 228 chevy 305 and alpha 1 outdrive. When I got the boat it had a SS 14.5x22 3-blade prop an it would run about 50mph but only turn about 3400 rpm. So I happened to have a SS 14.5x20 3-blade and it helped on the rpm and acceleration a bit. It would run 50mph at 4000 rpm and was still a little sluggish out of the hole. Pretty much all I do with the boat is pull BIG 250lb+ skiers. So I wanted some more pulling power. I put on an alum. 14.25x18 4-blade and it helped pretty good with holeshot, but now it only turns like 3600-3800 rpm at wot. Shouldn't I be able to turn more rpm now? Or at least the same as the 20" prop? I did lose top end speed down to about 42-44 and lost rpm. Did I miss something? Sorry my numbers aren't exact but I haven't had it in the water in a couple months now. I'm a bit bumfuzzled.
