Re: Prop clearance
What engine are you running?The anti-ventilation plate of the engines lower unit should be even with or slightly above the true bottom of the boat hull when trimmed level/parallel with the hull.This is just a starting point.Prop selection also plays a big role.<br /><br />If you don't have an adjustable jackplate ,the engine is either mounted too high or a different prop selection may be the fix.Let us know what engine you have and the prop diameter/pitch you are currently using.
