prop choice
tino
1991 16sl boston whaler ventura 91/90 hp yamaha 2 stroke cap/lbs 1320 - 24 gal tank has the tendency to ride with bow high up at low speeds.will a 17 pitch 4 blade prop help wih out decreasing optimum performance 4500rpm at wot
steelespike
Re: prop choice
What is your present prop? 4,500 rpm is pretty low.With any load you'll be running outside recomended rpm range.Something closer to 5,500 rpm wot would be better.As far as the bow rise I think something like smart tabs is a better choice.Improves hole shot,ride,bow rise and reduces no wake speed wander.4 blade might may help low speed performance but at the expense of top end performance.
tino
Re: prop choice
Thanks for reply Sir.I have 19 pitch on her now .Will get more infor on the smart tabs . thanks again Sir
