prop change question
ewolf
I have a Caravelle 188 with a 4.3 l mercruiser. It has a13.75 inch 21 pitch aluminum prop. It runs 44mph @4500 rpm. I want to change the prop to a SS 14.25 inch three blade. Should I go to a 20 pitch because of the diameter difference? A normal prop change in the same diameter will raise my rpm's 150 rpm which should be OK but what will the diameter change do to the formula? Will a 14.25 inch 20 pitch prop maintain the same speed as before but just help the hole shot?
Re: prop change question
I would stick with the 21P prop. Are you adding some rake? Consider a sternlifter type prop, as boats of your type will have a heavy stern.
steelespike
Is your prop old with plenty of wear? a Solas Amita or Rubex in the same size might improve performance.
They have a state of the art process.
There are others with better technical information.
But but to answer your question; speaking generally:: As you decrease pitch diameter goes up.
A 20 inch prop should behave like a 20" prop.A 1/2" diameter increase might might lower rpm 50.
But I'm thinking the ss prop will more than make up for any diameter change.
Prop calculator indicates about 20% slip.I believe the ss prop should improve slip.
Your looking for about 4800 max rpm I think the 20" might get it. Speed change may be a wash with a better hole shot
I did a little calculator check.
If, and it is a big if,A 20" ss prop can make 4800 with 10% slip you might see 50 mph.
Pure speculation.
tpenfield
Lots of variables to consider, so it is hard to say what the outcome will be
Changing material, which changes the blade thickness . . .
Changing pitch, which will change RPM & loading. . .
Changing diameter, which will also change RPM and loading
A 14.25 x 20 P prop does move a slight bit more water per revolution than a 13.75 x 21 P all else being equal . . . So, you might see a slight reduction in RPM with the bigger/lower pitched prop, but it should be real close.
To know for sure, you will have to try it.
ewolf
Thanks guys. All great points. This is much better than going to a salesman and have him sell what he only has on the shelf, if you know what I mean...
ewolf
With all of this discussion, should I consider a 14.25 inch 19 pitch instead of a 20p in order to get the rpm's up closer to the 4800rpm max?
Levinz11
I would get a 4 blade 19" Solas prop. It really gets my boat out of the hole well, lower planing speed, better speed at a given RPM, etc. Just my .02. If top speed is your concern stick with a 3 blade. Good luck.
