slowridertx
Thread starter- Joined
- Aug 2, 2010
- 2
Have a 2009 Honda 225- great engine- smooth on our 2010 Avalon 27' Ambassador. Built great, great engineering. Came with an Apollo stainless 3 blade 14 1/4 x 17" prop. Ran fine. Dealer provided a backup Apollo 14 3/8 x 15" to try for best performance due to some customization work that added weight and weight distribution. This weekend put the 15" on by the book and have replaced many props- no problem. Took boat out for series of WOT (5,000RPM) , 75%, 50% throttle runs and trim settings (I'm analytical). On first run at barely 2500RPM, felt a little flutter but went away. Ran for about five minutes to get momentum and then was going to WOT but before that at 4,000RPM, had massive cavitation/ventilation spin out. We stopped moving, engine spun up and I cut the throttle instantly. Kept engine in idle to cool her off for a minute then re-engaged up to slow 6kt cruise back to dock to ensure things going okay. Then in 10 minutes, heard another spin out/cavitation episode and prop stopped turning. Ended up having to get towed! Have had Merc and Volvo Penta engines- no problems. What on earth could a simple prop change do?? Prop wasn't torqued wrong, lubed, thrust washer fine. Hoping to God that Honda has a good destructing gear assembly so my main shaft is fine and just need some sort of prop shaft gear work. Should be (better be!) a warranty covered issue. Maybe prop was machined off spec? Appreciate group's knowledge base so I can have fair/balanced discussion with dealer, Honda, Apollo. P.S. Boat just delivered on July 4th and the 17" prop had no problems- just seemed like I was burning a lot of gas just for slow cruising (we aren't big skiiers or tubers- just sunset cruises.) Thanks !!! Slow Rider in Texas.
