Re: Prop blow out, needing help
If it was simply prop blow out that that you were trying to solve...with the a/v plate so deep.. the easy answer is add cupping to the prop (or a different prop) which will run in an aerated flow . You were going to provide tach data to confirm room for the plainly obvious and inexpensive solution.
The aforementioned often allows higher engine mounting, read more speed, less bow rise on take off, better mileage. From performance improvements, often times you can pickup the small rpm loss from cupping.
You should check your rpm's with the foil, which likely has been lowered, although you can try to "tune" the setup to recover the parasitic losses.
If you are looking for faster planing, lower planing speed, eliminating excessive porpoising, but increasing drag, then fine run a foil. The only concern with your design is that it is untested...
I would suggest that you are cautious doing your testing and in particular how those fins may dig in during a very sharp turn. If you were running in bigger waves in a following sea, that could be unstable. It doesn't sound like the latter would apply in this case.
Regardless, any solution that doesn't harm the motor(rpm wise) and gets you out and back safely is a winner.
