Prop and engine height questions
Faztbullet
Yep you're 101% right, that's why stated not knowing if having the shorter or longer plates distance. If hasn't changed in over 25 years must be the old height style, motors you like playing with.​
Your stating something that don't exist as there is no short or long plates distance. The plate distance on a 1977 V-4/6 is the same as a 2015 model. These are not old style motors ..you just have no experience with them.
Faztbullet
I looked today. The 4 blade is a shooter. I also was able to raise the engine a little. I was able to go 2 holes up which is about 1.5​
Make sure you have the clip in blow out ring installed..
