Maddoxsdaddy
Thread starter- Joined
- Sep 22, 2008
- 222
I have a 1995 Crownline 210 CCR with a 5.7L Alpha one and a gear ratio of 1.50. The boat came with 2 aluminum props, both have a couple of nicks in them. The dry weight is 3900 lbs. With 50 gallons of fuel, 3 people, gear, i'm guessing around 4800 fully loaded.
With the 21p, the boat is a slug out of the hole. The 19p does better and puts me in the middle of the WOT RPM range of 4200-4600. I want to go with a stainless prop but am unsure of 4 blade vs. 3 blade. Would a 4 blade 21p prop give a better hole shot while giving me a little more top end than the 19p or should i stick with the 19p to keep the hole shot? I don't pull anyone but don't want to be embarassed by a boat that won't easily plane with friends aboard.
Thanks in advance,
TB
Thanks in advance,
TB
