mercuryrising
Thread starter- Joined
- Apr 8, 2008
- 3
I recently bought an 01 Stingray 220sx with a 350mpi Mercruiser and a Bravo III drive. The prop is a double 3 blade 13.75" dia. 28 pitch.
It struggles to plane out with 500 lbs people/stuff but will do it in about 8 seconds. With 800-1000 lbs it won't plane out unless people shift into the cuddy cabin.
With 500 lbs. Wife and I and stuff, gps top speed is 48mph and rpms about 4800 WOT. It cruises nicely at 27- 30 MPH, at 3500-3800 rpms, depending on water conditions, wind, etc.
I would think this motor would perform better. I will be doing a compression check this weekend.
If compression is good, I will be changing props to be able to plane out with the added weight of a few more people but don't want to kill the top end or cruising ability.
I welcome some guidance on the right prop to go to.
