txmntman
Thread starter- Joined
- Dec 5, 2007
- 108
Hey folks, I recently purchased this 99 Montauk with a Honda 90 HP. boat is currently lightly loaded and only does about 31MPH. I am starting some troubleshooting, as I expected a little different performance. I really expected a little more top end speed.
* I will weigh the rig to check for water soaked foam, but doubt that is the problem.
* For those with this type of setup (I know there are some) what type props are you running?
* for those of you with this type of setup, what performance are you seeing out of your boat?
The specifics.
-speed checked by GPS, so I know that is correct.
-RPM running about 4300 at WOT
- Current prop is aluminum vortex from Michigan wheel, 13x19
-Cavitation plate is even with bottom of boat.
Thanks for your help!
The specifics.
