nothingspecial
- Nov 17, 2013
- 19
Re: Problems with first rebuild
Ahoy everyone, Thanks for all the good advise. Wow!-there is a lot of water drained from all plugs and hoses. That could have been costly. Well I had a nice day (25 degrees) so I wanted to adjust timing to 10 degrees past tdc. I did that but still had a lot of trouble with carb? I am still getting fuel out the exhaust with water. Even with new mechanical fuel pump. It wont stay running unless choke is about a quarter open. Wide open choke on warm motor kills it. I contacted the seller and they think it is a vacuum issue. I sent it back and will get a new one with an electric choke. I hope this is the "fix-all" solution.
