problems with a 1956 30hp evinrude lower unit
mike.1
i have a 1956 30 hp evinrude runs good but when you put it in forward or revers the moter jerks back&forth and it kicks out of gear
tashasdaddy
Re: problems with a 1956 30hp evinrude lower unit
bad clutch dog, and gears, unless you did not get the shift rod connected properly, last time the lower was off.
mike.1
does that mean ineed to replace the lower unit
tx1961whaler
If it's not just the shift rod, you do need to take it apart and see what's wrong. Usually a shift rod adjustment just affects either fwd or reverse, not both. If there is a remote shift cable attached, then try disconnecting the cable and manually shifting it.
56 rude
Banned
if your resonably mech inclined replacing a clutch dog is easy.the part is still avaiable from brp and a few of the aftermarket guys.get a manual as there,s lots of parts in there and i proably think you dont have the gift of outboard motor parts photografic memory,lol.i laugh because i do for some odd reason,i cant explain why nor do i really wont to know!.anyways i had the exact same motor and symptoms and clutch dog it was.look closely at the part and you will see where it worn ,it quite obdvious when you take it out and inspect.remember it doesnt take much wear to affect this part.have the part right in front of me and it says , omc genuine parts clutch dog 0375783 (on the parts box).hope this helps.
