jasper60103
- Sep 18, 2008
- 2,055
Just wondering if anyone had any tips for starting hot?
Seems to start-up OK when cold, usually within 2-3 pulls. It will sometimes die out though, but will start right back up. Btw, it runs like a champ and idles fairly well once it gets going.
I have more trouble getting her started hot. When I have problems I'm easily frustrated. I try starting with the choke in/out several times and adjusting the throttle until I finally get it going. Last time out, a good samaritan came along after noticing me wear my arm out. He made sure the vent was open and took a quick look under the hood. He concluded that maybe I flooded it out and suggested I take the choke off, and it did start after a few pulls. It died after about 30 seconds, but started up again.
Do you think my throttle position could be causing the problem? The start position is notched on the tiller handle, so I really don't know if this is really the sweet spot. Also, I never adjusted the idle speed. It was set by previous owner. Could it be the problem?
Should I choke when the engine is hot? How can I find the throttle start position?
At this point, I'm thinking my problems are operator error as I'm still fairly new to boating. Anyway, you have to start somewhere.
Thanks for your advice.
jasper
FYI. 1981 Johnson 25hp. Again this is my first season with this motor and boating.
jasper
