problem with leak on my 2003 alumacraft 175 trophy
pritch205
doe's anyone have a idea on how to stop the leak? it leaks somewhere under the rudder that runs the length of the boat. i have no idea what to do with it. thanks for your help. pritch205
Bob_VT
Re: problem with leak on my 2003 alumacraft 175 trophy
Welcome to iboats.
I will move this to restoration and repair.
There are NO seams under the keel strip....however you might have a crack or leaking rivets.
The best way is to get uner the hull and visually inspect. There are many products that will stop the leak and you might even be missing a rivet or two.
IF you have a livewell.....check the hoses too.
Midnight Krawler
Are you sure that the drain plug is not leaking?
