Problem with ignition, 1965 Johnson 40HP
AIRBORNE1115
Hello all, I'm brand new to boating and just bought a 1965 Johnson 40hp for my 1962 Starcraft Trihull 15'.<br />When attempting to connect the battery, the starter kicks over regardless of the key position in the ignition. Is there a way to test this ignition to see if it's bad?<br />Anyone know if $400 was a good price for this motor? The guy I got it from told me it was rebuild two years ago and that it runs well. I put the motor in a 55 gal drum and touched off the battery cables (as this is my only method of starting the motor at this point). It idled good and seemed to run fine.<br />My problem is hooking up the battery. It seems like the ignition is always hot...<br />Does anyone have a recommendation please?<br />Also, should I BUY an owners manual or a service manual or parts list?<br />Is it possible to download any of these online to save some dough?<br />Thanks
Lexington
Re: Problem with ignition, 1965 Johnson 40HP
Definately buy a Clymers manual if you plan on repairing the motor yourself. I bought one and it was well worth the $27.00. (sorry none for download....I looked)<br /><br />Does the motor turn over with out the key in the ignition? You can buy a new ingnition switch for $7.00- $15.00<br /><br />$400.00 is not a bad price if the motor performs well and it get you out and back.<br /><br />Have fun,<br />Dave
AIRBORNE1115
It does turn over without the key in the ignition. I bought a repair manual and realized that I don't have a voltage regulator!!(cylinoid*spelling?) Told you I didn't know what I was doing... hehe<br />I'll get one and hook it up, hopefully this will fix this problem of not being able to hook up the battery without sending power to the motor.<br /><br />Does anyone know if there is something that should be done to a motor of this age and type that hasn't been on the water in at least a couple years? Is there something I can do to "test" it in some way? It did idle well in the 55 gal drum.<br />I'm really sorry for these dumb questions, I just have no experience and would like any advice thats out there.<br />Thanks
