Problem with etec 115-2007 continuous buzzer and tachometer does not work
vento750
Hello everyone.
My etec 115 - 2007 has this prblema:
After a "SC" signal on the tachometer display the engine has started normally and everything is working.
At the next start-up, the buzzer of the tachometer emits a beep-beep pause bip-bip pause ... continuously, and xxxxxxxx appears on the display.
Starting the engine, this part but does not work the tachometer and the beep-beep continues even with the engine running.
I tried to take a ride with the boat and the engine works well.
What happen ?
Has anyone had the same anomalies?
I thank you in advance.
Greetings
Nico.
