Problem with 1969 Evindrude 25hp Hole in the engine....
razorsedge31
Friend of mine has this engine that is on his brothers boat and asked me to look at it. We take the cover off and first thing we see is the starter had lost a couple of bolts and was hitting the aluminum plate just above where the screw went. It must have been like this for a while because there is shavings everywhere..fast forward to today. I take the starter off real easy ..put it on my bench and hear a click....look in the bottom and the piece that you screw the bolt into for the starter has broken off at the block and now there's a hole.....here's the video I took....is there anyway to fix this? Here's a video....thanks for looking!
https://www.youtube.com/watch?v=A41aam1GluU&feature=youtu.be
GA_Boater
Can't see a thing when you link to a private video.
F_R
Honorary Supreme Mariner
If there is a hole through the crankcase, too bad, so sad. Major operation, replacing the block or powerhead. Might be weldable if you are lucky. You will have to evaluate it further.
Chris1956
I had good luck with marine-tex to seal a hole in the crankcase. It was a non-stress area that got a hole, when the motor fell off the stand. If the repair needs to support the starter, that is another issue.
Electric starter or recoil ?------Should be lots of good used blocks out there for that motor.
F_R
You will have to replace the block or whole powerhead. Yes there is alternating compression and vacuum in the crankcase, on each piston stroke, in a two-stroke engine. That is what pumps the fuel/air charge into the cylinder. Be aware that the cylinder block and crankcase (what you broke) are a matched set.
razorsedge31
Thanks. I figured that. Thought I'd might be able to swap it out...guess not. Thanks for the help!
