Problem remplacement oil mercury thunderbolt
Infomercury
Hi every one can u help me i have not information how to do a drain for the engine ? I do not find the oil filter and how to mix the fuel ? must mix with a bit of oil and what is the amount per liter? . Also the life of the engine oil . Help please it is old mercury thunderbolt inginition 50 hp
what year motor? that model number? serial number helps
if its 2-stroke without oil injection, you pre-mix the fuel and oil in the tank. ratio would be 50:1
if its a 2-stroke with oil injection, you let the injection pump inject the oil
if its a 4-stroke, there will be a sump that gets drained and filled along with an oil filter
There is no filter or engine oil sump on that motor.-----I suggest a manual for you to read about the operation of that old motor.-----Change the water pump impeller now before launching the boat.----Change oil in the bottom gearcase too.-----It might be best for a shop to look this motor over for you and give you some useful tips on how to operate it.-----Motors are often ruined by a novice !
Infomercury
Its 4 stroke it work but i cant find the place to change and controle (jauge ) the oil motor iam not expert and in our country we have not un expert for that motor and i have not a manual help me to get manual please
jimmbo
That is definitely a 2 stroke. 1972 - 1974 model.
4 cylinder
44.4 cubic in
WOT range 4800 - 5300 rpm
2:1 gear ratio
Infomercury
[No message]
jimmbo
That meant 4 cylinders. Inline 6s had a 6 there
What you are mistaking for a drain plug(upper yellow arrow) is a flushing port older mercs have.
The lower yellow Arrow is pointing to the vent/level for the lower oil. You fill the gear case from the drain/fill screw on the bottling front of the gear case till oil comes out the vent. You then let about an ounce of oil drain out the bottom and reinstall the screws using new gaskets
Infomercury
Ok i understand . I vérifie the lower unit and i see the oil mix with water i change the necessary and when i power on i see problème the moteur
only forward no reverse or weight bites Wha​​​​​​t cant i do ??
Alumarine
So you just have the forward gear?
Does Revers work?
Does Neutral work?
Did the gears ever work properly?
Infomercury
I have only problem with reverse
my boat does not go back the propeller turns well In revers but cant go
jimmbo
If the prop is turning in reverse, it should move the boat astern. If you try to increase speed, the exhaust coming from the prop hub will interfere with the props grip on the water. There is a possibility of the hub being NFG, have you tried a different prop?
danalex
Habla espanol? sprechen se deutsch? Parle vous francais? Possible language problem hurting you, else someone is fishing.
Infomercury
Hi Mr Fleet Admiral this year, I'm late, I'm finish my university studies, I just turned my mercury engine HP 500 2stroke it's an old engine Its not working I changed the candles and stop them does not arrive at the engine, I even changed "the two circulating between the two carburetors with the transparent pipe The gasoline block between the two carburators, and the motors dosent work (in my country we have not spare parts for this motors and finaly I am student no way to … its expensive).
jimmbo
"I changed the Candles and stop them does not arrive at the engine" ?????
"I even changed "the two circulating between the two carburetors with the transparent pipe" ??????
"The gasoline block between the two carburators," ??????
What exactly are you trying to say? If English is not your First or even Second Language, Write it out in your native Language, and use Google Translate, then copy and paste it
