Problem installing new prop shaft
petedw
I have a 1996 90tlru outboard I just bought recently. Found that the prop shaft was a little bent. Eventually got the old one out. Replaced the reverse bearings and kept everything else the same. Did my best to follow manual and diagram to put everything back together. Dog clutch sits in neutral and will shift to forward and reverse before assembled. shift cam is facing right way. when together It will only shift into reverse. The shifter will not turn into forward position. I'm wondering if I did something wrong with putting the dog clutch back on. Any ideas? I'm about to take it somewhere. Can't find any videos with anyone working on that exact motor. Thanks for any help!
