Primer valve on 115 evinrude seeping
dazieff
115 HP Evinrude 1992 is wet on primer prime run lever. seems to leak a little as it is wet at top of prime run valve. You can see it weep when you turn it. Would this effect motor at starting
Honorary Supreme Mariner
Repair parts are available.--Likely needs a new o-ring in there.
