Re: Primer for Gelcoat?
It won't cure or spray well at lower temps and depending on where you bought the gel coat they should also sell surface wax so it will cure correctly and not be tacky, its easier to use than PVA.
If you can't fine wax or PVA you can wipe the surface down with acetone to remove the sticky layer before sanding.
