primer bulb
vwfirehouse
My primer bulb is solid and cannot be squeezed after running engine. Is this normal?
R.Johnson
Re: primer bulb
The fuel pump is pulling a vacuam on the stystem. You have an obstruction somewhere. Primer bulb itself, anti-siphon valve, Fuel tank setting on the fuel line, (not unknown).
Vic.S
Re: primer bulb
You'd expect it to go a bit squidgy because as said the fuel pump is sucking fuel though it.
I take it the engine is running OK ?
If so the only reason I can think of for the bulb to be hard after running is if the tank is pressurised.
I dont think obstructions can do it
Not lying a lot lower than the tank?
vwfirehouse
Re: primer bulb
The engine runs fine up to 2500 rpms then stumbles and cuts out. If I keep it below 2500 rpm's runs all day. I reached down and made sure the primer bulb was full and it is hard and cant be squeezed. I was planning on replacing the fuel line/filter/plugs/and check the pick-up tube in the tank.
boobie
Re: primer bulb
Make sure you replace the primer bulb also. Have seen them where one of the check valves inside the bulb brake and restrict fuel flow.
vwfirehouse
Re: primer bulb
Replaced the primer bulb/ fuel line, and fuel filter. Emptied the bowls on the carbs and took her out yesterday. No more issues, ran great. Thanks for the help.
