Primer Bulb for Ficht Outboard
gscaton1
Just curious do you need to pump the fuel bulb for an Ficht Fuel injection outboard thanks I heard it is not necesary
Haffiman
Re: Primer Bulb for Ficht Outboard
If fuel lines are not leaking and stays connected at all times, it should not be needed to use the primer bulb on any outboard.
On carbed engines, the fuel vaporizes from the carbs during storage, and might need a re-fill by using the bulb.
The Ficht engines have a sealed vapor tank that normally stays full in addition to the pressurized injector circuit and as such may not need the priming.
boobie
I think I answered you back on this question on a PM.
Haffiman
Just to add to my earlier:
If you change some in-line filter/separator or install a 'dry' engine, you will need a priming system to get fuel to the engine!
gscaton1
Thanks everyone, great forum, big help. Still prime bulb and engine works great....
