swihartart
- May 4, 2009
- 82
Re: Prestolite trim pump
I've been down the long trim road you have and boy is it frustrating. I highly recommend going on ebay and buying a cylinder in good shape. I just checked and they are out there. actually there is a post with 2 good looking ones for $104 buy it now. I'm not promoting ebay but I picked a set up for $100 (I had a bad one also, same symptoms as you, also had a reverse lock that was out of adjustment badly) now I have a spare and it cured my problem right away and had alot less corrosion than the old ones.
I looked at rebuilding and read that they can be a real PITA and if you don't do it right, you get to do it again...and again...then what is your time worth, and the rebuild kit cost etc...
O rings that are on the "dog bone" on the bottom of your pump can be found at any hardware store...cheap. Mine blew too when the cylinder was bad, I guess because the pressure spiked trying to push the bad cylinder...orings are the weak point so they blow. No big deal to change.
