wolfscott
- Jul 20, 2010
- 51
Okay folks, I am confused here. I am running a 1973 mercruiser 165 I/O. It has a prestolite trim pump. The other day the clear plastic tube from the resovoir to the top of the pump let go, so I replaced it. I filled the resevoir, bled the lines, bled the trim cylinders, and gave it a test. The outdrive runs up fine, quicker than before, but on the down cycle, it hangs up about 3/4 of the way down and stops. I can have someone hold the down button in, and push down on the drive, but it will not go down by itself. I don't know if I am missing something here or not. Everything had run fine until I replaced the tubing. There is no pressure relief valve on this unit. To old I guess. I took the bleeder screw out as well, thinking maybe that would help. But nothing changed. One thing it does do is at full up, it slowly bleeds off and lowers the drive. Am I looking at a pump seal gone bad maybe? Any help or thoughts would be greatly appreciated. Thanks in advance.
