Pressurized Tank For Old Johnson
bhart13795
I have an old pressurized tank and cant seem to get it to pump fuel. I've changed my bladder and it still won't pump. Now I'm wondering if I put it back together correctly. In one part of the pump there is a tiny metal disc. Should there be a spring on one side of that disc or does it just set there by itself? I'm hoping that I didn't loose some small spring when I took the pump apart. it would be nice to see a diagram of that pump to better understand how it works and make sure I have it put together correctly.
Re: Pressurized Tank For Old Johnson
you should be carefull when working on small parts make sure the enviroment is clean when disassembling small parts so as not to lose anything, and if not sure research it before working on it, thats the only insight I have, sorry.
Fontanaman
Bhart,<br /><br />I probably have the diagram you would need. Let me know which tank you you have and I can e-mail the image if I have it.<br /><br />Adam<br /><br />whitewaterstudios@earthlink.net
oldboat1
Remove and check the intake screen and tube -- may have to clean one or both.
