I recently purchased a 6 gallon pressurized fuel tank, along with a 1957 Evinrude Sportwin. Before using the tank for the first time, I replaced the tank?s gasket (where the top plate mounts to the tank with the eight screws) with a new cork gasket that I purchased at a local Evinrude dealer (an old timer who has a lot of parts for vintage motors). After using it, I noticed some gas leaking out around this area. The original gasket that I removed was more of a paper material. Is cork the correct gasket material to use here, or did I just not tighten the screws enough? Also, what material do you use for the washers under the screw heads? They almost seem like a plastic or hard fabric.
I would greatly appreciate any help.
