Pressuried fuel tank gauge not working
roger56
Gauge on fuel tank is not working and not sure how to repair. Is this something that can be repaired or just replace tank?
Tank is on pontoon that can be removed.
dockrat100
Re: Pressuried fuel tank gauge not working
Is this a pressure tank? Old style with two lines coming off tank?:confused:
roger56
Yes with new in line filter
64osby
If the tank is delivering gas, I would be hard pressed to crack it open to fix the float. Just carry a spare 1 or 2 gal can.
Sounds like the float needs to be replaced.
Good tanks can run from $50 to $150 from what I have seen around SW MI.
If you crack it open, I would do a complete rebuild and be done with it. Should cost under $50 to rebuild it.
roger56
Thanks I will start looking for a new tank this one is 53 years old.
HighTrim
Well I will shorten your search, you wont find a new one, lol. They havent made them since the late 50s.
You could find an already working one, but not a new one.
Rebuilding them is easy, let us know if you need help with this.
roger56
Is there some type of replacement tank out there?
64osby
You either rebuild your tank, buy a good pressure tank, convert your motor to a fuel pump and buy a standard tank, or live with your broken gauge.
you might get lucky and be able to open your tank to fix / replace the float. That being said I opened one and ended up having to rebuild it.
Fry300
Rebuilding those pressure tanks is a fairly easy task. They are a lot more simplistic than one might assume.
