Re: pressure treated: to use or not to use???
My pontoon boat floor is 3/4" pt ply and only has a carpet glued on top. The underside is exposed to the water splashing up on it. It's a 1996 and the pt is still like new.<br /><br />nwright: The American Ply Association did a test on polyester resin sticking to pt ply. They found no difference in peel strength between pt and standard ply. BUT, the wood has to be dry.<br /><br />A cut and paste of mine from a previous post about PT:<br /><br />ACQ is the "new" pt process and more corrosive than CCA. They spec to use stainless or galvanized fasteners with it. ACQ has replaced CCA ONLY for residential use and not for commercial use.<br /><br />CCA is the earlier pt process and is still used in commercial applications and available everywhere.<br /><br />Don't be paranoid about using pt. I did a 17' boat stringers, floor and transom in CCA pt approx 4-5 yrs ago. I air dried the wood first and used epoxy to put it together. The boat has been in constant use on choppy coastle waters and gets beat hard, even in the open waters of the Florida Keys. Nothing has budged, cracked, delaminated, checked or shown signs of problems. It still looks like the first day it was launched and I will never have to replace the wood again.
