Pressure test shows leaks behind the yoke assembly
rodgeml1
I was going to replace the O-ring and oil seal in the roller bearing stack up.
Is there anything else I need to be looking for/checking?
mercs4mark
Re: Pressure test shows leaks behind the yoke assembly
If your pressure test did not indicate any other leaks you should be good, test after repair is done.
