pressure tank question
seeplaker
If someone was to find a pressure tank without the disconnect fitting to the motor, coudn't you just hook the fuel and air line directly to the motor without the fitting? What is so "explosive" about these tanks anyways?
tashasdaddy
Re: pressure tank question
sure you can connect directly to the engine without the coupling. they are no more dangerous, than a standard portable tank, use to day. it was the stupid people that caused that rumor. leaking hoses, etc.
wbeaton
What TD said. The quick is just a convenience, but worth it to me.
I run original pressure tanks and they work fine. All fuel tanks have the potential to explode.
