Anthonyfasttwin
Thread starter- Joined
- Sep 3, 2011
- 30
I have 4 pressure tanks all in bad shape. I have a 1955 fastwin I need to get running. Should I try to fix the gas tanks or go to a fuel pump system?
Funny thing about presure tanks is I've only read a few posts about trouble with them, But I've read a lot of posts about troubles with the single line conversions!
I keep the dual line tanks on Mine.
Good Luck.
Steve A W
If you have a bunch of crud in the bottom of the tanks put a couple handfuls of nuts (3/8) or so and swish them around alot to break the crud loose.
The problem with pressure tanks is that there are less and less of them around. If you go to sell a motor you have to sell the tank to go along with it as well. Many motors bought from garages and such don't have tanks. Best to learn how to convert one right.
That's quite true, but you have to be diligent in your search. In the past 3 years I bought a '55 Johnson and a '53 Evinrude Fastwin and both came with 2 tanks. I paid a total of $45 for all 6 items.
One of the tanks was an OMC oem replacement tank from the 1970's and it literally looked like new inside and out. I had to check old literature to confirm it....I never knew OMC sold 2-line tanks 20 years after they discontinued motors that used them!
THis Summer I bought 2 more old tanks for $5 apiece. Both had plugs on them as well. I din't really need them but at that price I couldn't resist.
Restoration is easy. Just a few gaskets and some hose. In addition to the nuts and bolts, I boil them out with water, then dry with alcohol. My 2 tanks that I use regularly have faired quite well, even 8 years after rebuilding.
Langsoutboards.comReading through this thread gives me the impression there is no one making new, 2-line pressure tanks for Johnsons, is that correct?
I picked up a '59 Johnson, 5.5 horse at an auction for $35 awhile back, but don't have it running yet due to lack of correct tank.
Any suppliers I can be steered toward?
Thanks.....Roger
