luckys pinstriping
Thread starter- Joined
- Apr 2, 2019
- 50
I have a 1984 Mark Twain with a OMC 2.5 liter motor. The out drive is a 400/800 stringer. When i went to change the oil in the upper gear case it had pressure in the case. I first unscrewed the top plug/dipstick and oil came out with pressure behind it. I then pulled the bottom plug and a small amount of water came out only a couple drops. the was milky white once drained clearly a sin of water. I recently resealed the upper gear case and made sure the four water pump bolts had plenty of permatex #2 sealant on them when installed. I did not change the impeller or housing at this time. Any ideas where this water is comign from and how to correct? I assume the pump is forcing water into the gear case somewhere.
Thank you Nick
Thank you Nick
