Prep work for Paint ?'s
Tazman282
So I have read every thread back to 2008 and understand that the prep work is the most important. In regards to prep work, how much sanding are we talking? I did a pretty lousy job on my deck as far as fiberglass as in it isn't totally smooth, I have been sanding for days with 40 grit and it just doesn't seem to ever totally smooth out evenly and if I hit the same spot long enough it seems to leave resin on the pad which then requires another pad. Is this normal?
I am unable to feel a difference barefoot, but when rubbed with my hand I can feel unevenness but very smooth. Is there a better method to sanding and what would be the final sandpaper grit before painting 120?
I have been looking at options for paint and am leaning towards Rustoleum Marine Grade, what do you think of this method: "One trick I used when painting my boat with Rustoleum Marine paint was to mix it with 30% mineral spirits. This thins the paint just enough, so the paint will "lay down" smooth, giving you the desired finish. I only wet sanded the primer, not the paint."
I am planning on the roll/tip method as I have never used a spray gun.
Any info you can provide is greatly appreciated, I am just looking to finish this boat as it has almost been shipped off to the junkyard on two occasions and if not done soon a third.
Tazman282
Re: Prep work for Paint ?'s
Also, must I use gelcoat to protect the fiberglass or can I just paint the fiberglass?
oops!
you can paint the deck....rustoueum is fine.
the way to get it flat is to sand with a long sanding board.
a small sanding block will be tons of work and you will never get it even.
see if you can find a boat sanding board if you really want results......its twice as wide and a foot longer.
after the 40......go 80...then 120...
oh......and sand the high spots...not all a round the highs....just the highs.
Tazman282
Well I am already using an orbital sander, is a big block sanding board better?
Perhaps I am just trying to make it to perfect in the first place, I already hit all high points, it just isn't nearly as smooth as the original walls. Hopefully once I finish with the 120 and paint, it will be what I am looking for. I think I may have used to thin of fiberglass in the first place and the reason why it isn't totally smooth like my transom which I used Biax on. Also, would you recommend adding the 30% mineral spirit to the paint to thin out?
Ciera2450
If you roll and tip, I don't believe you need to thin the paint. Thinning makes it easier to spray.
I have rustoleum for several boat projects and have never thinned it.
You can add an enamel hardener that will increase the durability and gloss of the paint
Woodonglass
Check out Page#10 in my "My Flamingo" thread listed below. It has all the details you need on how to apply your Rustoleum paint.
oops!
yeah...and rustolieum is such thick paint that it lays flat every time.......you will have no worries
Tazman282
I was thinking about just giving poliglow or biokleen a go on the outside hull or should I just repaint. Last painted 10 to 12 years ago.
ezmobee
We had a member use poliglow and was initially thrilled with it, however it went bad somehow (I forget what happened) and he ended up stripping it all back off.
Yacht Dr.
Need Pics please ..
Deck .. Fordeck or like Cockpit deck .. ? ..
What is it your doing here..
Pics are needed please :) .
YD.
