Pre Alpha Prop?
MikeySpeedR
Hey all, so I’m in need of a new propeller (ran aground in a low tide, dinged it up pretty good). Running into a snag though...
Every prop/hub kit I’m finding it for post 1983 alpha’s/bravo’s. I have a ‘77 model (serial # 4792163).
Boat is a ‘77 Sea Ray SRV-240 with a Mercruiser 250.
Current prop is a 15 3/4 x 17, but it's not right for this boat. While it's got good top speed (33mph at 3200rpm, will not rpm anymore), it's slow to plane and will not reach WOT rpm (valve cover says 4500 iirc).
Anyone have idea’s?
alldodge
Running that low rpm at wot I'm wondering if either the motor has low compression, or the drive ratio has been changed and its to high.
MikeySpeedR
Motor is fresh. Makes great oil pressure and on land I can rev easily to 4500.
According to the serial on the drive it’s correct for the year.
alldodge
The drive is the right type but unless you bought it new, the ratio could have been changed.
Reving in neutral doesn't mean anything, there is no load
Can either remove drive and count the drive and prop shaft rotations
or
Bypass the neutral safety switch and disconnect power going to the coil.
Put in Forward
Connect water to drive
Mark the crankshaft pulley and the prop
Have someone crank the motor and count 10 revolutions
Have another count the prop revolutions
QBhoy
Anyone have idea’s?
Hi. I’d say your tachometer is way off. 33 mph would be about right for speed. But I’d say there is little to no chance it’s doing that at only 3200 rpm. Usually those rpms would be about minimum planing speed for a set up like that. Around 20ish mph. If for some crazy reason the tachometer and speed were actually as reported…it would mean it would have such a prop pitch and or drive ratio…that would surely mean the boat wouldn’t get close to planing at all. If you get me.
MikeySpeedR
I do. I’ll have to check the tach signal though. It doesn’t sound like 4500 rpm though. It could be off only a few hundred if that tach was wrong. Instead of 1000.
I am still searching for a correct prop though.
Scott06
Unless someone swapped the wrong ratio drive on it, verify the tach first before playing with props. Unless the engine needs work/tune up, the hull is water logged would expect a 17" to pull way more rpm than 3200. What is the mantenace hsitory on the engine- I know you said compression is good, what about fuel system and ignition components? Reving under load doesnt take much power so that isnt an indicator of good running condition.
what are the compression numbers? post them
what is the fuel pressure going to the carb?
what is timing?
what do your plugs look like?
motor with bad compression running on 1 cylinder will rev to 4500 RPM in neutral. that means nothing
define "Motor is fresh"
