Powerhead swap between 68 18hp, and 75 25 hp
Rwed
jimmbo: what if i keep same carb on that 25hp head? keep it at 18hp?
Rwed
Guy sent me pics of underneath of the ph. to check for scouring. how does it look?
kbait
I’d pass.. both cylinders have scoring.. you’re looking at a fair amount of work to swap to a marginal powerhead.
Honorary Supreme Mariner
He removed the exhaust cover on the side of the block.-----Run away-------See post # 10.
oldboat1
So, why not work a little more on the one that's stuck. Tilt it up and fill the cylinders with ATF. Let it set for a couple of days, refilling as necessary -- see if you can get some movement.
Rwed
yeah, the whole goal was to get a decent powerhead, to make a running motor as cheaply and efficiently as possible, this is the 3rd ph that's w good compression, but no count.
oldboat, do i need to remove the head before i start messing with it? or just work through plug holes?
Remove bypass cover and inspect pistons and rings.------That will also allow you to fill crankcase with oil.
oldboat1
Looks like someone was in process of working on the cyl head (one bolt partially removed) -- looks like the original gasket, but hard to tell. I would take it off, but take care particularly if a salt water motor. Run them in and out a little to make sure they don't break. With the head off, you can gently work on the pistons to free them up. Worth a try, anyway. Will be messy -- protect the floor.
Rwed
ok, so, this feller, went all out. and based on response from the J&E FB group, those pistons and cylinders look good.
I'm not here to question the experts.
Based on the photos i just posted... what do you guys think? he took head off to peer inside
