Re: Powerhead problems ?
Any motor can ingest water spray through the air intakes of the engine cover. Usually you will find a speed wheel, transducer, or hull fitting that is spaying water up near the motor when running at speed. Just like a station wagon with the back window down on a dusty road, an outboard also has a low pressure area just behind it and can suck the spray into the vents and all over the motor.
