joesarasota
Thread starter- Joined
- Feb 15, 2009
- 1
The Power Tilt & trim on my 1991 Johnson 90hp suddenly got stuck in the up position. When I use the Trim switch I can hear the motor run in either up or down position, but no tilt movement. So I assumed the problem is not electrical but within the PTT unit itself. I tried added Dextron II hydrolic fluid as my service manual called for, but it was allready full. Then I tried to manually lower the motor by opening the manual release valve screw a couple turns counter clockwise and nothing happened. I tighted the manual release valve screw & tried the Trim switch, again I can hear the motor run in either up or down position, but no tilt movement. Any recomendations appreciated???
