Power trim unit
misdeal
Rebuilt power trim unit not working
hello everybody,,,i just rebuilt my power trim unit, got it back on the boat and,,,,it dont work,,i can hear the motor run when i push in the switch,,1st time i hit the switch the 2 lower piston arms came up but when i relased the lock on the motor and tried to lower it it wouldnt go down or up, so i opened the maual release and the motor came down to the lower pistons and stoped,they wouldnt push in,, again up or down i can hear the motor run but nothing moving, could it be a fluid problem as in to much ? the trim unit is on a 1989 johnson 120hp,,,thanks for the help,and happy easter OLOR]
Big flop
Re: Power trim unit
It should be filled when in the full up position.
If it's still part way up try to add fluid &
hit the up button to bleed out the air.
Cycle full up & Down a couple of times &
Recheck level when all the way up.
misdeal
Re: Power trim unit
Thanks i will give it a try,,still not sure why the lower pistons wont push in even with the manual release open
