Power trim & tilt
gleavin1
The power trim & tilt works fine on my 98 Johnson 90. The indicator gauge no longer works. Needle doesn't move. What is the most likely cause and can you tell me how to troubleshoot & fix the problem?<br /><br />Thanks...Gene
tazatax
Re: Power trim & tilt
gene the power trim & tilt positioning switch is just under the pivot point on the motor. trim all the way up and look just above pt&t assembly there will be a plastic lever that is supposed to move as the motor goes up or down. most times the spring goes bad.
gleavin1
tazatax,<br /><br />Appreciate the information, now I've got a starting point.<br /> <br />Regards...Gene
