Power trim / tilt on a 2004 4 stroke Johnson
ronjon27
I was having an intermittent problem with the manual trim tilt on the side of the engine. The upward direction worked fine but I couldn't lower it consistently. I replaced the lower relay only to have the problem continue. Any suggestions?
jakedaawg
Does the switch on the remote control work both ways? If so, replace the cowl switch.
ronjon27
The switch on the speed / direction arm hasn't worked for sometime. I am specifically referring to the power trim switch on the engine. It goes up great but I have intermittent problems with lowering it.
