power trim swap
i have a 1990 omc 2.3l
the motor for the power trim went bad, cost to replace just motor alone was $400
there were lots of complete unites on ebay for much less so i got one of those. anyone see any issues with this swap?
also, with the drive unit in the FULL UP position, see any reason for not starting the motor to warm the oil for a oil change?
thanks
Steve
Ayuh,.... Welcome Aboard,.... That'll destroy the u-joints in very short order,....
thanks
Steve
do you know that the pressures are correct with your new pump and the old system? if not, you can damage things
regarding the drive in the full up. I wouldnt start the motor. as Bondo stated, you will tear the u-joints up really really quickly, then it takes out the gimble
