RE: 1987 115 HP I6 ELPTO
My power trim unit is shot, so I received a replacement that will fit - with no wiring diagrams - and is wired very differently than the old original:
(UPPERCASE = LARGE POWER WIRES, lowercase = small signal wires)
Old wiring: red-white, blue-white, green-white wires from trim switches to up/down solenoids, with BLACK GROUND and BLUE & GREEN POWER WIRES from the solenoids to the trim motor. Red-white wire from the harness (switches) has a fuse that then connects to the solenoids with RED BATTERY POWER (from starter solenoid) connected through both solenoids on the opposite end (What is the purpose of this?)
New wiring: RED FUSED POWER WIRE to blue wired relay, and BLACK GROUND WIRE to green wired relay, with each relay having small (signal) wire (with white stripes) and LARGE (POWER) WIRE to be connected to the trim motor, along with multiple black (small) wires connecting between the relays.
I assume I remove the solenoids and install the relays with the RED FUSED POWER WIRE connected to the starter solenoid (battery), and connect the thin blue-white and green-white signal wires directly to the trim switch wires of the same color, connect the respective BLUE and GREEN WIRES to the trim motor, and connect BLACK WIRE to ground in the motor. If so, what do I do with the fused red-white wire coming from the trim switches?
Or, could I just keep the solenoids, and connect the respective BLUE and GREEN wires between them and the trim motor?
I need a quick fix as I?m water-bound with our without power trim next week. I prefer with.
