cwalls5656
Thread starter- Joined
- May 21, 2012
- 18
I have an 84 procraft. It has a johnson gt 150 v6. The power trim stopped working (kind of)
it will go down, but wont lift the motor up. when i try to raise it, sometimes the relay just clicks, ( i changed the relay out but that was not it.) it does this on all 3 toggle switches. the fluid is full. i put a test light on the blue and green wire going to the motor, and i do have power on the wires going to power trim motor. when it does start to lift the motor up, it only goes 1/2 inch or so, and sounds really weak. is it the power trim motor, or what do i need to check?
thank you for taking time to read, any suggestions will be appreciated
thanks
thanks
