Stan's Customs
- Oct 30, 2004
- 161
Re: Power trim causes power loss on OMC Cobra...?
WEll... <br /> the distributor part came in and after the rain let up I was able to put the boat on the lake. The wrongly positioned ignitor plate was most of the problem. The engine goes to 4600 easily with me only in the boat. It would probably go higher trimmed out further, but that's about it for the cam, judging from the increase in rpm without increase in power. I figure that a loaded boat will keep me at max rpm @ wot and full trim. I really thought this boat would be way under proped with this 17, but it seems good. It's a Four Winns 200 with a 5.7 Cobra. Most of my similar boats in the past used a 19 to ski..sometimes a 21, never a 17.<br /><br />Now back to the other problem...When the trim is "bumped" the motor cuts out a little. But when the trim is firmly held in it does "not" cut out??<br /><br />I generally just bump the trim till it sounds good, so this is really awkward. When you nail the switch it doesn't cut out just goes to far. When you just bump it it cuts out a little and you can't tell if it sounds just right ..if you get my meaning. (right before cavitation).<br /><br />Seems like it would be worse the longer you hold the trim button in ...but no. Does that still act like the trim motor is pulling too many amps or some similar problem? Could it be the control handle switch someway?<br /><br /><br />Thanks ...Stan
