Re: Power Trim and Tilt
Are you repairing or adding? If youa re adding, be careful as there are two factory type power systems for this motor. One is Tilt/trim and the other is Tilt only, but on the surface i svery similar and was a dealer insalled option. I believe the difference is that the tilt has 2 rams and the trim only has one. The trim unit cannot operate while the motor is over 1000rpm or so, but will work for navigaing shallow areas at very slow speeds.<br /><br />As 73 said, check out the CNC PT-130 unit if you are adding and want trim.
