scottykrug
Thread starter- Joined
- Jun 19, 2006
- 8
I have a 1997 Mercury 115 hp ELPTO that has started having tilt issues. It will tilt up with no issue, but will not tilt down unless you tilt up first and then quickly reverse it and go down. When you select down either on the shifter or the switch located on the motor itself, you can hear a "click" at the relay, but the tilt motor does not turn on. We replaced the relay just in case, but it seems to have the same issue regardless. First thought was a bad switch, but both shifter and motor switches have the same issue. Second thought was a flat spot on the shaft in the pump motor, but why would it work up but not down? Thoughts? The parents are taking the boat on a fishing trip this next week and I wanted to get it fixed before they left.
Thank you in advance...
Scooter
Scooter
