I recently discovered a leak that drained the hydraulic pump to the power trip of my Mariner 45 horse. While it looks like the hoses could be replaced, I think I found the real problem. The oil is leaking through a hole near the bottom of the pump where a ball bearing usually resides. I found the ball bearing at the bottom of the boat where the pump sits.
What is it going to take to seal up this hole. Does the pump need to be completely taken apart and will a new ball bearing stay in place? Why would that ball have come out in the first place? As a novice, I am pretty sure that I will need to have this problem fixed by a professional. However, I am interested to know what type of job this would be if I did decide to tackle it myself. Also, if I decide to replace the four hydraulic hoses, what type of job will that be. Do the hoses usually come with the proper fittings on both ends, or do the hoses need to be cut and crimped to fit the situation?
I am attaching a photo of the style of pump that I have.
Thanks
Thanks
